Sponsored by: Innova
2006 e-350 nav message
Old Jul 15, 2013 | 03:55 PM
yikes's Avatar
06 e350 17 glc300
hello
i just got message and i believe the nav player is gone bad.
no dvd
please insert a NAV-DVD
(car trunk)
btw...i use an original HK 2013 v12 disk and have tried other older version since getting this message and no change
can anyone confirm that the nav player is bad and can this be fix or do i need to replace the unit
thanks
Old Jul 15, 2013 | 07:25 PM
yikes's Avatar
06 e350 17 glc300
also need to add that ive been using this disk fine since january or february 2013
this issue started only today
thanks
Old Jul 15, 2013 | 11:15 PM
yikes's Avatar
06 e350 17 glc300
well i got a can of spray air and sprayed it into the dvd slot a few passes
now the disk drive is working again.....maybe just a dirty laser???
Old Jul 16, 2013 | 06:17 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Indeed, likely a dirty laser. You might also clean the DVD too.
It is less than likely that the air got rid of dirt; if the laser was dirty, a DVD cleaning disc might be helpful. They're available at big-box and audio stores.
Old Jul 16, 2013 | 09:56 PM
yikes's Avatar
06 e350 17 glc300
thats a good idea...ill do that
thanks
