Sponsored by: Innova
Connecting MP3 player to Command
Old Sep 5, 2003 | 04:02 PM
bdr2's Avatar
I seem to remember some time ago reading about someone installing an MP3 player into their 2002 c-class with command. They also mentioned connecting it via a special connection in the glove compartment.
I have a 2002 C32 with Command and factory CD changer in glove box. I recently looked into the glovebox and could not find any connections (maybe covered by the CD changer?).
Since Command does not have a cassette, I need a more direct method to connect the player. The command menu has an ability to access an Auxiliary Device, so there should be a way to connect to this Auxiliary input.
Old Sep 5, 2003 | 04:23 PM
rmklaw's Avatar
2004 CLK 320 and 2004 Porsche Cayenne
AUX input
I had the installer add the four AUX wires to the C2 connector to the Comand.
Old Sep 5, 2003 | 04:24 PM
rmklaw's Avatar
AUX input
I had the installer add the four AUX wires to the C2 connector to the Comand. I have a Sirius satellite radio hooked up to the AUX.
Old Sep 5, 2003 | 09:51 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Connecting MP3 player to Command
You mean YOUR COMAND doesn't have cassette. There are COMAND units with cassette.
Anyhow, you need to take a better look in your glovebox. If you have factory COMAND, the connector is on the right side of the glovebox near the door.
-s-
Old Sep 6, 2003 | 07:34 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Re: Re: Connecting MP3 player to Command
HERE to be exact...
greetingz,
