Sponsored by: Innova
99 clk 320 no a/c
Old Aug 25, 2013 | 09:45 PM
lvincent89's Avatar
ON SUSPENSION
99 benz clk 320
99 clk 320 no a/c
I have a 99 clk 320 the a/c compressor will not come on I don't know much about these cars but it was completly outa freon I fixed the leak an started to fill to 1.9lbs got one can in an compressor didnt come on to put the rest in I figured it was like most cars an you have to bypass the pressure switch to get it to take the rest before it would come on but the pressure switch has three wires put my meter on it an found two legs to have 5volts an one ground does any one have any info on bypassing these or just run a hot leg to the clutch?
Old Aug 26, 2013 | 07:00 AM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
Hi, sorry for your troubles. You do know that this is the audio an electronics sub forum, where people discuss subwoofers, after market head units, nav system problems and the like. You might have better luck posting this in the general clk forum. Good luck and welcome to mbworld!
