Sponsored by: Innova
need to change audio system of w203 C class 200 Kompressor
Old Oct 5, 2013 | 03:26 PM
kushrai's Avatar
Mercedes Benz C200 Kompressor
Hi,
I am from India and I need to change / upgrade the Audio system of my C Class 200 Kompressor w203 model to touchscreen audio system having Bluetooth, ipod connectivity & navigation system. I need a best brand for this upgrade. I can invest till $800 on the upgrade. Kindly let me know the best brands available for this upgrade.
Best Regards,
Kush Rai
Old Oct 6, 2013 | 10:03 AM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
Lots of choices out there. You seem to have an idea about what functionality you need from the unit which is always the first question. Also I assume that when you say replace audio system you only mean the head unit in the dash and not replacing all the speakers or the amplifier. Therefore assuming just the head unit again lots to chose from. I would suggest that you go online to sites like sonic electronic or crutchfield and plug in your car info and review the many models there. Then after you identify one or two speak to the reps there as you need to also make sure that whatever aftermarket head unit you get will still work with your steering wheel controls, etc. Depending on the model you choose you may also need adapter units to interface between the new head unit and the steerong wheel controls, for example. Good luck.
