Sponsored by: Innova
Adding JL 12W6v2 subwoofer to COMMAND system
Old Nov 20, 2003 | 02:35 AM
ronnie0738's Avatar
2003 Nissan 350Z
I'm planning on adding a single JL12W6v2 off a JL500/1 to the C32 command system. Would I be able to use the stock sub input with a high-low converter into the 500/1? Also, would a cap be needed when I want to bump the tunes?
Old Nov 20, 2003 | 05:04 PM
lebomb's Avatar
2000 C280 Sport
Yes.....It can be done....here is proof.
Attached Thumbnails Adding JL 12W6v2 subwoofer to COMMAND system-ampsub2.jpg
Old Nov 20, 2003 | 07:23 PM
ronnie0738's Avatar
2003 Nissan 350Z
Cool...so you used a high-low into your amp? Do you think I need a cap for the 500/1? Thanks.
Old Nov 21, 2003 | 12:14 PM
lebomb's Avatar
2000 C280 Sport
I didnt do the install, I had custom sounds here in SA do it. I believe they used a line converter. I really dont think you need a cap at all. I have 350watts to my single 12" sealed box and it pounds! I have the sub ported to the interior thru the ski hole. Good luck!
Old Nov 21, 2003 | 12:22 PM
ronnie0738's Avatar
2003 Nissan 350Z
Sounds good. Thanks for the info. I'll post pics after my install.
Old Dec 6, 2003 | 07:42 PM
N.M.M.'s Avatar
You DO need a high to low converter to install an amp.
