Sponsored by: Innova
CLK SRS Light on after seatbelt repair
Old Feb 25, 2014 | 07:44 PM
alfredman's Avatar
M-B 2003 CLK 500
I have a 2003 CLK 500. The driver's seat belt retractor broke. I replaced it with the exact part number but continue to get the SRS light and a message that restraint systems needs servicing (the same message I got initially when the retractor spring broke).
I was told that if you replace the seat belt unit the same part the SRS fault should clear itself. It has not.
I tried to clear the fault with a Snap-On diagnostic system but keep getting faults, SRS light, message.
My question is: Do I need to use the M-B Star system to clear the fault codes, because the Snap-On system can't, or is there an issue with the part I replaced, the wiring or the restraint system control unit?
Thank you in advance.
Old Feb 28, 2014 | 04:30 PM
funnyent's Avatar
c230k
SRS errors usually have to be cleared by STAR in order to go away. You'll end up paying about $100 to have the dealer clear it but it will get rid of the annoying errors.
Old Feb 28, 2014 | 08:04 PM
alfredman's Avatar
M-B 2003 CLK 500
Thank you
Thank you. I will have the shop use the Star Diag system to reset the SRS while they are repairing the A/C flapper door control arm that recently broke.
