Sponsored by: Innova
AC problems 2006 E350
Old Oct 6, 2014 | 11:49 AM
TonySnyman's Avatar
350E 2006
Hi all, I am looking for some advice on my 2006 E350 (right hand drive).
I noticed the other day that the AC was not cooling very well. I suspected that I had lost some gas (134A) and Put my guages on to check pressures. I had 155psi Hp and just under 2 bar lp which means there is enough charge. I then discovered that it is only the driver side which is not cooling front and rear. The passenger side is cooling fine.
Is there one evaporator for both sides and how many fans are there? I checked fuses but did not find any that were bad. Im sure this is quite a complicated system and I have absolutely no knowledge of the climate control but suspect it could be a simple solution if you know where to look.
Any info will be greatly appreciated
Tony
