CD Changer Installation help
I was wondering if you have any instructions on how to hook up the optical cable on a 2000 S430.
I found the power supply and the CD cable wrapped up behind the amp. The CD changer is A203 820 9089. I am guessing that the cable has to connect between the changer and the amp. The cable is Y shaped, with one end that fits into the large connector on the CD changer. The other side is a small square optical “male” on one end of the Y, and the other end is a larger square optical “female”. Where do these connectors go ?? Am I missing something ??
Thanks...Mike
