Beware of PAC SOEM-4.
To make a long story short, the SOEM4 was connected to constant 12v which is typical for the bright yellow wire that it uses. However, in this configuration, the remote wire leaks 1.25 volts which will turn on and leave on your Bose amp.
So... for those of you using SOEM-4's, connect the yellow wire to switched 12v and not constant 12v.
Hope this saves someone all fo the frustration I've been through the past 6 months.
-J
However, if they meant for it to be hooked up to switched 12v they should be clearer with the instruction and wiring colors.
If they were correct with wiring colors and meant for it to be constant 12v its a cheap design that leaks voltage where it shouldn't.
-J
