Around week ago "Dipped beam, right" message appeared at my W211 E320CDI 2007 facelift model dashboard:
When I stopped the car and checked the light then it indeed was off:
Now yesterday also the right headlight stopped working and both "Dipped beam, right" and "Dipped beam, left"messages appear at the dashboard. If I checked the fault-codes with Torque application over the OBD, then it did not detect anything.
I guess it is highly unlikely that both headlamps fail almost at the same time? Are there any additional diagnostics which I could do to narrow down the cause? Am I correct that my model has bi-xenon headlights?
Thanks for the reply! Is there a way to test this? In addition, am I correct that level sensor ensures that both headlights are at even height? And light motor raises the headlights once the engine is started?
I'm speaking from my experience with my E55 here...
Level sensor on my car is a lever-activated potentiometer with the lever end attached to the rear sway bar on the centerline of the car.
The headlights should have stepper motors that adjust the headlights up and down based upon inputs from the rear-mounted potentiometer.
A diagnostic system will read and test all of the above. You can use the diagnostic system to cycle the headlights from full down to full up and the set them for automatic to work off the level sensor on the rear swaybar.
I have a post ref R&R of the stepper motor assembly over in the W210 section when I re-furb'd the headlights on my W210. Might give you an idea of what to look for. I would assume (not promise) the W211 stepper motor assembly would be similar.
Which diagnostics system do you mean? MB Star diagnostic system?
In addition, as I understood from your and jbondox answers, the common part for both lights is the lever-activated potentiometer connected to roll-bar? Each headlight has probably own stepper motor?
I'm not familiar with your car and can't make definitive statements about it.
Xentry DAS. The older C3 system is making it into the market place. And the potentiometer is attached to the rear sway bar. Hard to see and harder to get to it. A Xentry DAS allows you to read the sensor output while one of your friends moves the rear bumper up and down. The Xentry DAS is expensive but worth every penny. Plus, you can sell it for what you paid for it.
Not that you should need to do so but...for the W211 you have to remove the bumper to remove the headlights. If you go this route, search for my user name in the W211 AMG section concerning PLM Heat Exchanger Install. It'll help you to remove and reinstall the bumper.
You can sign up with the Mercedes EPC (Electronic Parts Catalog), enter your credit card info (but it isn't charged), enter your VIN, and the EPC will read back everything about your car. The Bi-Xenon will have the ballasts for the high-voltage bulbs.
The issue looks like a bad bulb. You just need to remove it (see your owner's manual) and replace with a halogen or Xenon. If Xenon, it's gonna be expensive but buy two and replace them both. If Halogen, less costly but still buy two and replace both.
