Cutting power supply to the Viseeo MB-4 Bluetooth cradle?
Mercedes C 280
I use Bluetooth over the Viseeo MB-4 with an Android phone in my 2005 W203. Once connected to the car, the Viseeo MB-4 switches itself on, even when the key is removed from the car. I’m afraid that it will drain the battery when I don’t use the car for a while. Has anyone experience with this? How can I force the car to cut the power supply to the Bluetooth cradle? Thank you!
Mercedes C 280
A little update:
I locked the car while I was inside and waited a couple of minutes until it was low on oxygen ;-) After a while, the device was switched off, so I assume that the power supply was cut, regardless of an inserted car key.
