Burmester Speakers Buzzing like Kazoo
The 2016 C300 on loan was just as bad. This seems like a system wide issue, and anyone bothered by buzzing speakers are just out of luck.
I guess they expect us all to be part of the MP3 generation.
http://youtu.be/q2-m4_-ZLRE
I see you touching the grill like it stops when you touch it, maybe that is just the resonant frequency of the grill itself. If it is the grill then a few things can be done, new grills, add some weight to it towards the outside of the grill from the inside sparingly to not block the sound, sound deaden the door and then you can also add a speaker foam kit to the speaker itself... basically foam that will encompass the speaker from the back of the speaker to the door panel and from the front of the speaker trim to the back of the door panel.
i got to head to Bedford MB later this week, I will check a vehicle when I get there.
Also, is this only Bluetooth, or does it do it on CD also?
The service folks also mentioned a customer that listened to piano, and everytime certain notes were played her speakers buzzed. They did not fix her car either. Pianos clearly shouldn't have 88 keys, not acording to Burmester or MB.
I would hold on to the loaner, but is also aweful. Blah.
You can always try contacting Burmeister and ask them. MB Customer care also. There is an audio shop that specializes in a lot of MB stuff in Cleveland, access1alarm.com but I am sure it will not be a in and out scenario.
