Sponsored by: Innova
Difficulties with Kenwood DPX306BT
Old Dec 30, 2015 | 04:38 PM
Alex Di Palma's Avatar
C Class Coupe 2003
Hi there,
I previously changed my stock head unit with a Pioneer one, but have now upgraded to a Kenwood double din. I am unsure how to connect it. Will I need any additional looms? I have attached pics to show what wires I have for the new unit. Is it as simple as plug and play? (my car is a C180 Coupe 2003)
Any
Thanks!
Old Dec 30, 2015 | 04:46 PM
PeterUbers's Avatar
So long as you have the correct wiring harness kit and antenna kit it is plug and play
The pioneer double din should come out and the kenwood should go in
Only thing that may be different if you plan to use steering wheel controls ... Usually a special unit for this
Old Dec 30, 2015 | 04:54 PM
C Class Coupe 2003
Yeah am not too fussed about steering wheel controls. Will give it a go tomorrow and see what happens!
Old Jan 1, 2016 | 07:46 AM
C Class Coupe 2003
Ok so I am after a little advice and expertise here. After disconnecting the old head unit, I am left with the loom and one wire connecting to the original loom. I am assuming that wire is a power cable. So is it a question of disconnecting that wire from the old loom, and to connect into onto the new head units loom along the red wire, where there are bullet connectors? I have included pics as its hard to explain.
Attached Thumbnails Difficulties with Kenwood DPX306BT-image1.jpg   Difficulties with Kenwood DPX306BT-image2.jpg   Difficulties with Kenwood DPX306BT-image3.jpg
Old Jan 3, 2016 | 08:11 AM
C Class Coupe 2003
All sorted now thanks
