Sponsored by: Innova
Re Audio Build | AudioCityUsa | 12" RE Audio SE | RE Audio SA Amplifiers
Old Jan 21, 2016 | 11:35 AM
AudioCityUsa's Avatar
Former Vendor of MBWorld
2008 mbz cl 550
For this build we ran 2 12" RE Audio SE Subwoofers, with a custom ported box, and 1 RE Audio SA 3000.1 & SA 90.4. The Door panels are fiber glassed with 4 6 1/2" Coaxial RE speakers, and 1 6x9.
For any detailed information feel free to give us a call
(626) 814-1158
Rims Online | After Market Wheels Deals | Truck Wheels & Tires
audiocityusa.com by Audio City, on Flickr
RE Audio Build by Audio City, on Flickr
Old Jan 21, 2016 | 08:58 PM
jbondox's Avatar
beater with a heater
Poor car
Old Jan 23, 2016 | 10:35 AM
hillcreative's Avatar
2011 E350 Cabriolet
Can you say Tinnitus? Speaking as an ex radio DJ that used to wear a set of Koss Pro4AA headphones to work every day, you should be concerned with the volume level in your ride (or anywhere) you will end up with that funky whining sound when you hit 40 and I don't mean your supercharger!
Old May 24, 2018 | 10:28 PM
Acapulco Bill's Avatar
2010 C300 Sport
@MB Marko - It is not just a question of swapping the speakers - the headunit must be replaced, wiring must be changed due to the configuration of the headunit, the subwoofer amplifier installed with a special wiring harness and connected to the HK headunit via Toslink fibre-optic, fuses changed... It's a massive undertaking and have heard of no one making the complete Audio20 to HK Logic7 swap.
The speakers are low efficiency and must be equalized and time-aligned with custom profiles in order to sound "normal", just installing the drivers (of course the subwoofer will have no amp) will result in deficient incoherent audio.
Suggest selling the HK speakers if you are not prepared to spend hundreds or even more than $1,000 and invest a substantial amount of time and effort trying to make this upgrade work - the audio equivalent of turning a C200 into a C63. As a primer, here's a popular thread about upgrading the sound of the Audio20 system: https://mbworld.org/forums/c-class-w...r-upgrade.html
Best of success.
