Nokia Signal weak with Booster, Please help
2015 E250D
I have the nokia 6310i kit and installed a seperate Hirschmann Antenna. THe signal is ok but not that great. It's usually always full when not plugged into the cradle. I bought a 1900mhz antenna compensator from Mercedes Benz which is suppose to increase the signal but it actually LOWERS the signal strength and then the signal is really bad. Anyone have any idea why? My teleaid antenna is out of the circuit totally and is left alone. I did not mess with this at all since I bought the Hirschmann antenna. Can something be wrong with the compensator?
I would guess that something is wrong with the compensator then???
Because my 6310i works perfect with the Hirschmann antenna.
Was this always a problem, or did it just start? Why dont you try another antenna from a local audio shop?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
2015 E250D
If I plug in the Hirschmann antenna to the phone antenna wire directly, than it's pretty ok but not that great signal. I got the antenna after reading your post earlier. When I plug the antenna throught the compensator, then it's not so great at all. Is your antenna plugged directly into the phone antenna cable or going through the compensator? Also, do you have a part number for the compensator you are using?
