2001 CLK-430 Can you use TeleAid GPS Antenna for Comand GPS?
Thanks in advance
RK
Techinically you can use the Teleaid GPS antenna but you will have to run some wires and buy a electronic splitter from Benz. Not really worth all the trouble. Stick the antenna behind the guage cluster and it works fine.
Its more work to do it but I think I am getting better reception than using the same antenna under the dash. Just my two cents.
Take a look here for the DIY project ...COMAND 2.0 Retrofit
Paul
I just did a COMAND retrofit in my '01-C320. I used a splitter and a new coax cable. They were cheaper than buying the antenna? My dealership listed the stick on antenna at $120. The splitter was $65 and the coax from the rear window to the center console another $35.
Paul
I bought a 1-piece antenna for ~$45, so I think mine was quite cheap.
In regards to better reception, I found that mine had great reception... I didn't mount it under the dash (which is why you prob had poor reception), but my antenna is not in clear site... not even if you tried looking for it.
Paul
