C300 power seat not working
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
It is a very simple system----switch----door control module -------motor!!
and before you tear into the door panel disconnect the battery for five minute--reconnect---do you still have the issue!!
You have me confused----I suggested to disconnect the main car battery and if you have a second battery disconnect that also--the task is as if you were turning off and on your computer---in this case it is all the cars control modules that you are turning off and then reconnecting and then they will be on----do the now seats function
