Can This Be Done (Integrated Phone/Radio Question)
Not a Benzer anymore
With the integrated Phone:
Scenario:
When you make a call, you can either do it with the menu display saying AUDIO or When the menu is on CellPhone.
When it is on Cellphone, you can enter numbers and both the dashboard and radio displays will display the number dialed. This does not happen when the menu is on Audio.
Ideally, there should be only 1 method to access the cellphone (through the cellphone menu)...
Can the dealership disable the AUDIO part of the cell phone integration?
Scenario:
