Subwoofer in 124
I have swapped my subs with others, so I know it is my trunk, not the equipment I am using.
I have been told it is the position of the gas tank in the 124, and a peice of steel sits betwen the rear seat and trunk, is there any way for me to get aorund this and allow bass into the cabin?
Someone suggessted cutting a hole in the rear deck to allow sound to come in, but I can't justify cutting a hole in my Merc.
Thanks for your help!
Sam
If you want bass, do some cutting.
You could consult with a GOOD high end stereo shop and see what sort of custom solution, they could create for you.
What you are doing is equivalent to having a tiny air intake and tiny exhaust, but adding 17psi boost to a Normally asperated engine. It is just a waste of energy and dollars.
Should I cover them with a grill?
If I remove the speakers, will I have a 'tunnel' so to speak from the speakers to the trunk?
