Sponsored by: Innova
w211 sound
Old Sep 7, 2017 | 05:41 PM
Munin73's Avatar
C320
w211 sound
Where is the original amplifier place?
What is colours of the amplified wires to speakers?
Can I put a audison bitone on it?
Old Sep 13, 2017 | 01:49 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
In the boot (trunk) on left hand side, tucked up between inner and outer wings - you will have to unscrew and move aside the small fusebox there, and then there are a couple of bolts on the inner wing you remove, and a nut on the wheel arch at bottom of bracket.
I can't remember the colours. If you have the "non HK system' there is 1 plug with all the speakers on there, and the amp itself is low power so you can feed it into speaker->RCA converters etc etc. If you have HK amp, its all much harder
R
