Sponsored by: Innova
Comand not working?
Old Feb 11, 2018 | 05:53 PM
Vilpo's Avatar
Audi S4 -99
Comand not working?
Ok, so i have gone through just about everything troubleshooting this Comand issue.
The car is GL450 cdi -07 x164.
The problem is the comand turns on from the button, show mercedes logo. Then turns off by itself after about 10-20 seconds.
Sometimes it can very seldom turn on by itself and work (radio on and sound works) for maybe 1-2 minutes then turn off again.
Now at first i tried all the reset procedures but none work. Then i bought a bypass adapter for the MOST bus to test if some component of the system is not working and thus making the comand not work.
But bypassing all other components didnt make the comand work. And it seems fiber optics red light is going through the system full loop (starting from comand/agw and ending to cd changer, well comand again).
One thing that is strange to me that i cannot connect to comand unit with star diagnosis through the audio menu. I tested the can bus lines from the unit is connected to the body can split on the car (both high and low).
So right now i conclude that the comand unit is faulty.. Are there any other ways i can test the unit before buying a new one? Just want to make sure before paying big money for it.. :/
Or anything else i can test? Any ways to bench test comand?
Thanks for any help..
Old Feb 13, 2018 | 08:10 AM
Vilpo's Avatar
Audi S4 -99
Originally Posted by Plutoe
Are you serious---find someone with a copy of DAS Xentry and run a quick test and all will be clear
Did you read through the whole post? I have star diagnosis unit and i have tested using das Xentry but the audio control unit cannot be connected to at all.
Old Sep 19, 2018 | 03:56 PM
Sumit Bhasin's Avatar
W221
I have the same problem. I figures out a workaround to make it work. I hit the ON/OFF button repeatedly till the system boots up after 10 seconds. It then runs fine till the next time I start the car. Hope this works for you.
BTW, where did you buy the fiber optic bypass loop. The ones they are selling on eBay/Amazon are not the correct type for the Mercedes.
Old Sep 21, 2018 | 04:41 PM
Vilpo's Avatar
Audi S4 -99
Ok, thanks for the hint but doesn't help for me anymore. I did buy the comand-unit and that fixed the problem for me.
I did buy the loop adapter from ebay, and it did work on mercedes. The same as here for example: https://www.ebay.com/itm/Fiber-MOST-...9XBfD2&vxp=mtr
Old Sep 26, 2018 | 12:14 AM
W221
Check out the fiber optic bypass loop this guy uses on his S550. It looks nothing like the one being sold on eBay. Your thoughts?
Old Oct 1, 2018 | 04:59 PM
Vilpo's Avatar
Audi S4 -99
https://www.youtube.com/watch?v=GH2V...-WJ4wnJcE8T8u5
Yes, that one sure looks a bit different. But for me, the one sold on ebay did fit, the car i was working on is Mercedes GL 420 CDI, -07.
It is Euro model car, maybe the connector is different? Or year model difference?
