Sponsored by: Innova
Fiber Optic CD Changer Install
Old May 17, 2004 | 09:15 PM
Sam 325i's Avatar
Turbo Diesel
Is it possible to put a MB fiber optic cd changer installed to an aftermarket Alpine deck? or would i need a newer fiber optic head unit also?
Old May 19, 2004 | 12:00 AM
MeeM's Avatar
I'd be inclined to think that it is possible to do this. I'd say it would work if the MB CD changer was made by Alpine (some are made by Alpine, some by Becker, some by Panasonic, and some were by Sony). Check if it's made by Alpine, and perhaps ask around before trying.
Old May 19, 2004 | 11:55 PM
Lynn's Avatar
Re: Fiber Optic CD Changer Install
No.
Old May 20, 2004 | 06:49 PM
clkal's Avatar
01' CLK55
the newer cd-changers are made by becker. not compatible with any alpine aftermarket decks.
Old May 20, 2004 | 07:00 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Re: Fiber Optic CD Changer Install
How much newer? As far as I knew, they were made by Alpine.
My 2003 E55 has an Alpine changer in it.
Regardless, as Lynn stated... any fibre optic MB changer (Alpine, Becker, Panasonic, no matter) is not going to work with an aftermarket Alpine deck.
-s-
Old May 20, 2004 | 07:02 PM
scorchie's Avatar
Can you tell me which fibre optic changers were made by Sony? I've yet to see one and would like to see it. Most people are surprised to hear that I have a Panasonic-manufactured fibre optic changer.
Which incidentally, uses cartridges made of unobtainium.
-s-
Old May 21, 2004 | 09:53 AM
FernandoSLK's Avatar
SLK 230 K 1998
And how about a MB Audio 10 CD made by Alpine, will an aftermarket Alpine cd changer work with it? I'm not sure if my 98 SLK has fibre optic conections or not. How can I check it? If so, the cd changer has to be fibre optic as well? Has Alpine fibre optic aftermarket CD changers?
Thanks to all!
Old May 21, 2004 | 02:52 PM
scorchie's Avatar
Thanks to all!
Audio 10CD uses a fibre optic CD changer.
Your 1998-manufactured SLK probably does not have fibre optic wiring, because most non-US cars not delivered with CD changers do not have fibre optic wiring; plus your car may be a bit too early.
Alpine does not use D2B fibre optics in their aftermarket products.
-s-
Old May 23, 2004 | 02:58 AM
SLK 230 K 1998
So do you think any regular (no fiber optic) Alpine CD changer would work in my car? What is D2B? Anything else should I need?
Thanks for the info.
Old May 23, 2004 | 03:03 AM
SLK 230 K 1998
