How do I wire up COMAND HU coded to "no amp"?
First, from what I've read here I assume the only way to code the HU for no amp is using a Star diagnostics unit...if that's mistaken please let me know.
Otherwise, if I want to use the 4-ch line-level signal from the HU how is the wiring run to my outboard stuff? And can I use the factory wiring to the speakers? I haven't removed anything yet so don't know what I should be looking for. Thanks!
Well, what I gathered so far, is that you can code HU for no amp through engineering menu in COMAND (google it, I do not remember from top of my head for button combination, something like "pickup phone"+"1"+"# ").
As I understood you can get 4-ch unprocessed signal directly from HU, but you have to run wire from HU to amp location.
You can use factory speaker wires, but they run individually to each raw speaker, because crossovers are built in in factory amplifier. The only thing is not clear front doors midrange and tweeter, some folks says it is common wire for both of them and tweeter protected by a capacitor, other says they are on individual wires from factory amp.
Still looking for exact details.
Now we need to find pin out diagram for speaker wires coming from amplifier in a trunk ;-)
How is your progress on upgrading?
Staying simple and 100% analog was my original plan, but using newer technology is so tempting.
The factory wiring to the speakers goes to the amp which is in the trunk. So I'd probably replace the amp there, and run some Speaker -> RCA converters and RCA leads between.
Easiest thing for wiring the head unit is to get a SOT lead for Mercedes and then use that to run to the RCA converter as there is no speaker connector in your Quadlock at the moment ..
Cheers
RIchard
