Sponsored by: Innova
Is this OK to do
Old Jun 21, 2004 | 01:49 AM
r207's Avatar
w203
Is this OK to do
I have hooked up a DVD player in the trunk like this
From DVD player
Acc wire to FUSE #7 in the rear SAM
Constant to the constant fuse in rear SAM
ground to the cosest metal part of the car.....
Is this ok or do i need to wire it differently
Old Jun 21, 2004 | 04:12 PM
Peench's Avatar
2002 C32 AMG
You are probably going to want to run your constant from the positive terminal of the car's battery as opposed to a fuse. Other than that it looks alright.
Old Jun 21, 2004 | 04:19 PM
Brunelleschi's Avatar
In the market
But just to clarify as I know Peench know's although it was unsaid...be sure you run that constant power through a fuse block of some kind to the battery.
Old Jun 21, 2004 | 09:01 PM
r207's Avatar
w203
The rear SAM does have constant power, it does have a fuse also between it and the DVD player, isnt this the same as constant power
Old Jun 21, 2004 | 10:06 PM
In the market
That it is, but you are then sharing a power source with a deticated fuse that serves a specific purpose. It will work and you will probably never have a problem, but I think it would be safer to run a single deticated source from the battery. Just IMHO
Old Jun 26, 2004 | 05:24 AM
r207's Avatar
w203
i have used a fuse that is spare, the appliance is not hooked up to fuse number 7
