W176 Electronic steering lock damaged
I have no power on dashboard and after I have run diagnostics it come up with error EZS – Electronic Ignition lock (N73)
B225464 The electronic steering lock has a malfunction. There is an implausible signal.
It seems they tried to jump start the car with the ignition key in, and this has damaged the communication between the ignition key and the electronic steering lock.
I have now a second hand steering lock same model but it needs to be programmed between EIS and Ignition key.
Does anybody knows if a second hand electronic steering lock can be re-programmed to the car original one? Does anybody knows who can do it?
I had the same problem, sorted by a guy on ebay:6222mercedes. He provides an plug and play emulator instead for £140
07801695627
https://www.ebay.co.uk/itm/MERCEDES-...4.m46890.l6249
