W166 NTG 4.5 sirius xm missing from radio menu
Recently I installed a android smartbox to the system and in the engineering menu I made some changes to the AUX configuration, but now I noticed that the XM Sat is missing from the Radio drop down on the screen. I cant recall what changes I made and perhaps I chamged something else too by mistake. how can I get that Sirius xm feature back?
Were you able to fix this problem?
I have the same situation, were you able to figure out how to get your satellite radio back? I also notice my FM 1 & FM 2 are gone also.
Go back in MOST in 7.5 TGW PARAMETER and change SDARS back to INSTALLED and reset the unit by holding the on button for about 15 secs. Worked for me after in installed Car Play and lost the Sat radio option.
The following 3 users liked this post by Alex Ung:
GL350
Thanks for the help on this and for what its worth , any change i made within the Eng mode did not save or set until i hit HW setting/External video display/END/Yes to Do you want to close. Comand restarts and applies all the changes.
