Sponsored by: Innova
moving phone memory on comand system
Old Jul 4, 2004 | 09:03 AM
monty's Avatar
sl 500
really confused about speed dialing using Nokia 6310i phone with Comand system. Is it possible to rearrange phone numbers so that we can allocated memory location with the phone numbers.
i have got the names on the phone, say for example SALLY number is in memory location M014. For her to be in speed dial section, the memory location must be in M001 to M009. How do I move her name up the list from M014 to M008 for example.
Old Jul 4, 2004 | 12:03 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
I believe you need to save it as a speed dial on your phone first. Then it will occupy memory locations 2-8. 1 is voice mail, 9 is emergency, so are generally unavailable for use. I think if you turn off the "emergency 9" feature you may gain use of that location again, or alternately you could store your own number in the emergency number setting.
-s-
Old Jul 4, 2004 | 05:30 PM
monty's Avatar
sl 500
will try again
sorry , it does not really work. i did it to the phone , but once in cradle it is no longer available
but will try again tonight,
thanks for advice
monty
Old Jul 4, 2004 | 05:44 PM
scorchie's Avatar
thanks for advice
monty
Is your C200 a W203? I will try it in my G500 (same phone system as W203) in a little while... I am pretty sure it works somehow on my system.
-s-
Old Jul 4, 2004 | 09:18 PM
SUNILP's Avatar
2015 E250D
I am using the nokia 6310i UHI phone with command and speed dial does not work with my kit. I have to manually press the phone button. The command buttons don't work....... I think. Also, the memory on my phone has to be stored on the SIM card for the comand to see the numbers. This is really easy to do with the nokia since it has the copy all feature.
Old Jul 4, 2004 | 10:05 PM
scorchie's Avatar
Mine definitely works (speed dial, I just tried it by holding down a number on the COMAND keypad). I think it can also access phone numbers in the phone in addition to ones in the SIM, but only if it is a primary number.
I have no idea how to store things in certain memory locations on my Nokia. It's easy with Motorola, but somehow I set mine up and have no idea how I did it. Maybe using the computer software?
-s-
Old Jul 5, 2004 | 05:29 PM
SUNILP's Avatar
2015 E250D
Scorchie,
I just tried mine and it works fine too but it speed dials from the number that is on the SIM card and NOT phone memory. whoooo hooooO!
Old Jul 6, 2004 | 09:06 AM
monty's Avatar
sl 500
congratulation
well done
i had to manually erase all memory on the sim card of the phone, and then manually via the comand system insert the first 10 phone numbers in to occupy the memory spaces for speed dialing
ie M001, M002 .....
does your speed dial number 1 work - mind does not , goes to some funny nokia number
monty
Old Jul 6, 2004 | 09:50 AM
scorchie's Avatar
well done
ie M001, M002 .....
monty
Well, that's the one thing I had right... it's in the first reply to your post. You can change the #1 number too.
-s-
Old Jul 6, 2004 | 10:42 AM
SUNILP's Avatar
2015 E250D
Mine goes to voice mail.
