Need Help for speaker upgrade
I need to know if anyone has used say a 4 channel amp and added a new sub to the back tray in replace of the stock sub...the stock sub sounds crap and i think it needs to go....
Im assuming a 10inch will fit or maybe ill go two 8inch as i dont have first aid kit in the back
If you give more details for what you are looking for with price and what kind of music you listen we can be more help.
I run a dedicated 4 channel amp that powers a set of components and rear fill. Then a dedicated sub amp for a single 10 inch. If bass is not a serious concern you could get a free air 10 inch from Kicker or Diamond Audio. Anything other then the stock sub will require some work and mounting technique.
