Sponsored by: Innova
Alpine Model CD changer for stock head unit?
Old May 3, 2002 | 06:26 PM
Betsblack's Avatar
C230 KMT Coupe
Does anyone know what model CD Changer I can use for the stock head unit in the C230 Coupe? I'm getting desperate here (my fiance can install it). Please help!!!
Old May 3, 2002 | 10:02 PM
BrabusCClass's Avatar
GL450, Sienna SE
Try the search option in the C W203 forum. I saw it mentioned there before.
Old May 6, 2002 | 10:20 PM
Cryptnotic's Avatar
The changer is indeed manufactured by Alpine in Hungary. However, the interface is not a standard Alpine interface, but is rather the Mercedes D2B Optical interface.
Autoclass (http://www.autoclass.net) sells the changers and necessary optical cables for around $400. These are the same actual Mercedes-Benz brand changers with the optical interface that the dealer sells for $800.
Another option is to use a CD changer with an RF modulator interface. If you're not using the ashtray, you can mount the controller box into the ashtray space. Or you could use the sunglasses tray underneath the head unit and drill a hole for the wire to run through.
Probably the best option is to replace your head unit with a high quality aftermarket head unit and aftermarket cd changer. Some head units will look nice in the stock location once you make a black plastic bevel to go around it. A good example is the Nakamichi CD-45z-a (Amber version). It's probably the highest quality audio for its price range and the changer would fit nicely in the glovebox.
Old Jun 14, 2002 | 01:46 AM
mlracer's Avatar
You can find the MB fiber optic changers at http://store.autotoys.com - search under fiber optic
