Sponsored by: Innova
Radio lights not coming on with headlights
Old Aug 9, 2004 | 05:34 PM
DWM's Avatar
DWM
E420
I replaced the original radio on my '97 E420 with an Audio 30 BE 3309. Now the radio won't light when I turn on the head lights. Any ideas? This function on the original radio worked fine and I've tested and Audio 10 and t works fine too.
Old Aug 9, 2004 | 05:39 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
I think the BE3309 gets illumination over CANBUS... and your radio wiring doesn't bring CANBUS to the radio.
First, check the radio in a newer installation, if possible, to make sure the illumnation is even working. It might be as simple as a bulb!
-s-
Old Aug 10, 2004 | 10:04 AM
DWM's Avatar
DWM
E420
There's something funky with the power-in on a couple of levels. Besides the light (I have not yet checked the bulb), the radio does not shut off with the car. I can live with that but would prefer not to have to fool with it.
Thanks.....
Old Aug 10, 2004 | 02:22 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Also a CANBUS related issue...
greetingz,
Old Aug 10, 2004 | 07:18 PM
DWM's Avatar
DWM
E420
No fixing that either?
Old Aug 10, 2004 | 07:50 PM
scorchie's Avatar
Probably not worth it...
1) CANBUS simulator will turn illumination and ignition power signals to CANBUS data.
2) hardwire illumination wire to bulb inside radio. Still won't shut off with the car
3) Figure out the CANBUS illumination for your climate control, and feed that to the radio. Even with that I think your car doesn't have ignition over CANBUS still.
4) Switch radios to an older Audio 30, I think one that only has 3 pins in the C connector instead of 5.
-s-
Old Aug 12, 2004 | 06:20 PM
DWM's Avatar
DWM
E420
Ok, dumb question.... How to change/Check a bulb in the BE 3309 Audio 30. The light and display appears to be in the small front that lowers for the tape. I took it apart but all I have is a small panel of which one side is the display.
