W211 Nav module (DVD) self-install
Has any one done a self-install of the Nav module for a W211?
I'm talking about the unit that goes in the trunk.
I've just received the unit and the replacement panel, but I don't see any instructions.
Is it possible to get the instructions off a website somewhere?
TIA.
- keyless go
- parktronic
- dynamic or orthopedic seats
- foldable rear seat
If you have none of the above, you need another trunkliner. If you only have the foldable rear seat, you need a different trunkliner. If you have the other 3 options, or just one of them, you don't need anything else; the current trunkliner will be just fine.
Greetingz,
BigSis
What I've got is a kit with the DVD drive mechanism, the replacement side panel and two mounting brackets/mechanism chassis. The MB part # is 6-7-82-3252.
After removing the existing panel, I've been able to connect the DVD mechanism and I know that I can install the replacement panel.
However, I can't make out how affix the brackets to the car.
TIA.
