Sponsored by: Innova
DO I NEED THIS THING?????
Old May 30, 2021 | 03:27 PM
luckychuckie1's Avatar
clk320 wife, s5amg sold :-{(
I've read that I will need a bypass coupler.... or radio won't work, SOS will flash, I'll hear voices,
I 'am taking out the COMMAND - new head unit JENSEN, - OUT TO NEW AMP - REUSE WIRES TO DOOR SPEAKERS.
So THAN can I get rid of it, it's in the way of putting in new subwoofer. thanks!!!!!!!!!!!
Here is a complete list of all wires in the Amplifier plug UNLESS YOU HAVE CONVERTABLE [img]file:///C:/Users/Charles/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gif[/img] (see attached pictures too!):
Amp Wiring
1. BROWN (big wire): Chassis Ground
2. RED with VIOLET strip (big wire): 12 Volt Ignition/Acc
3. BLUE with WHITE strip: Amp Turn-On (Remote)
INPUTS (from Headunit to Amplifier) - 8 THIN wires:
4. GREEN: + Left Front (input)
5. BROWN with GREEN strip: - Left Front (input)
6. ORANGE: + Right Front (input)
7. BROWN with ORANGE strip: - Right Front (input)
8. PINK: + Left Rear (input)
9. BROWN with PINK strip: - Left Rear (input)
10. WHITE: + Right Rear (input)
11. BROWN with WHITE strip: - Right Rear (input)
RUN RCA CABLES FROM NEW HEADUNIT TO AMP
OUTPUTS (from Amplifier to Speakers) - 10 THICK wires:
12. GREEN: + Left Speaker and Tweeter in the Front side of the door (output)
13. BROWN with GREEN strip: - Left Speaker and Tweeter in the Front side of the door (output)
14. ORANGE: + Right Speaker and Tweeter in the Front side of the door (output)
15. BROWN with ORANGE strip: - Right Speaker and Tweeter in the Front side of the door (output)
16. PINK: + Left Speaker in the Back side of the door (output)
17. BROWN with PINK strip: - Left Speaker in the Back side of the door (output)
18. WHITE: + Right Speaker in the Back side of the door (output)
19. BROWN with WHITE strip: - Right Speaker in the Back side of the door (output)
USE THE 4 PAIR FROM NEW AMP TO DOOR SPEAKERS AND RUN SPEAKER WIRE TO NEW SUB FROM NEW AMP.
20. GRAY: + Left Speaker(subwoofer) in the rear deck (output)
21. BROWN with GRAY strip: - Left Speaker(subwoofer) in the rear deck (output)
22. VIOLET: + Right Speaker(subwoofer) in the rear deck (output)
23. BROWN with VIOLET strip: - Right Speaker(subwoofer) in the rear deck (output)
PS- I moved the box under the above fiber box till I realized it was the rollover sensor....🤷‍♂️ any tricks I need to know in resetting.... to get the rear headrests to go down?
Thanks💰
