Sponsored by: Innova
Comand NTG2.5 DVD Changer issues
Old Sep 13, 2021 | 03:56 PM
wasterfd's Avatar
91 500SL E60 sold, 2002 C32 Amg sold, 2006 S350, 2004 CLK 200
Hi,
I bought a 2008 W211 with a Comand APS NTG2.5 with the built in 6 DVD changer. All other functions of the unit seem to be Ok but unfortunately the DVD changer does not work properly. It makes noises as if it is cycling but nothing happens. If I want to load a disk I select a disk and press OK expecting the message "please load disk" but this does not happen. After some time the disk selection screen will reappear.
What I have done so far:
- Opened up the unit and found 5 cd's in the changer. None of these would be played and none of them could be ejected the normal way.
- I took the dvd changer apart en took all disks out. As I was not sure what the starting position was of the various actions I experimented with no luck and probably broke a plastic part that moves the laser head in and out.
- I bought a new DVD unit of eBay, put it in the Comand and emptied the error log. Unfortunately this did not solve the problem. The symptoms are as mentioned above. I can not load disks.
Is there anyone who has had this problem and has a possible solution maybe? Thank you for your help!
Kind regards,
Frank
Old May 14, 2025 | 09:12 AM
gtodoroff's Avatar
GL550
Originally Posted by wasterfd
Hi,
Kind regards,
Frank
Hello I have the same issue... Anyone knows what to do. it happened after restart.
Old May 14, 2025 | 09:13 AM
gtodoroff's Avatar
GL550
Have you found how to fix it. Have the same problem after command restart.
