Using duo-SIM phone connected via Bluetooth
When connected via Android Auto, you can use the AA Phone interface to make the call (there it works when 1 SIM is default, but also when you have to choose SIM 1 or 2 just before calling). This is a (clumsy) workaround, but does anybody here know how to make calling numbers work again with 2 active SIMS active (of which 1 is default for calling out) using the MB COMAND Phone menu?
Was about to install this app on my phone: https://play.google.com/store/apps/d...ltisimselector that seems to solve the issue for some people.
But just before, I got an Android 11 firmware update for my phone, installed it, and after this...........it worked as it should be! So using COMAND Phone it chooses the default SIM as set in the phone (without using the afore mentioned app).
So problem solved!
