Sponsored by: Innova
Command system - swapping or fixing?
Old Feb 9, 2022 | 05:19 PM
MurrayG's Avatar
AMG GTS (2016), GL63 (2016), SL63 (2022) -- Old Cars: E400, CLS 63s, ML 63, CL 600, S550 ...
I have an unusual issue with my 2014 S550. Here are the symptoms:
  • I cannot store or import phone contacts.
  • the system does not show my paired phone's contacts,
  • it does not show any recent numbers dialed,
  • Furthermore, I cannot store addresses in the navigation system (regardless of whether a phone is paired).
This seems to be a broader "contacts" issue with the command system.
Everything else I have tried on the Command system works fine.
I took it to the dealership where they said they reset the system and then updated the software. No change - the system will still not store or display contacts. They said the only other thing to try is to replace the Command system.
If you think there is some potential fix other than replacing the command system, please advise.
If not - what are my options WRT possibly finding a used command system / module from a wrecker and replacing the one I have? Obviously having a new one installed at the dealership is prohibitive.
Please advise if you can!
Many thanks and have a great day!
