Sponsored by: Innova
Inner door panel with window regulator reattachment?
Old Mar 17, 2022 | 10:27 PM
nelsonford218's Avatar
2022 GLB 35
I've got a glb 35 I'm wanting to put some door speakers in. The inner panel is riveted to the door itself and will have to be drilled out to remove it. I'm considering different options for reattaching them and looking for suggestions. Would prefer to go with a method that will allow me to remove them again if needed without having to drill and rerivet them each time. That about nutserts but couldnt find any that fit the 1/4" 6.3 mm holes that were already there and dont want to drill them larger. Considering using well nuts, basically a rubber rivet. Any opinions on whether these would work well? Anyone used another method?
