Sponsored by: Innova
phone installation problem
Old Oct 13, 2004 | 07:00 PM
mesallem's Avatar
2000 ML430
I installed the phone kit myself and now i am getting the srs and airbag off sensors on, i am wondering if it has anything to do with the phone. i have not been to the dealer to do the aam coding, would that have anything to do with it?
Has anyone else had this problem?
Old Oct 13, 2004 | 07:32 PM
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
Was the battery disconnected while working on the wiring?
Were any of the yellow airbag connectors disconnected?
Old Oct 13, 2004 | 07:49 PM
mesallem's Avatar
2000 ML430
no it the battery was not disconnected when i installed it and i did not remove the airbag connectors at all, everything was still connected
Old Oct 14, 2004 | 02:36 AM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
I am not sure but I was told that you need to disconnect the neg of the battery before working on any electronic of the car. Correct me if I am wrong.
Old Oct 14, 2004 | 12:32 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Depending on the work, disconnecting the battery on newer cars that can definitely be a bad idea. Each job needs to have considered the possibility of shorting things out versus the reprogramming requirements, and for almost all jobs, it's more efficient to leave the battery connected. This is especially true if the person doing the work does not have a list of reprogramming requirements, or sets out knowing that he will not do the reprogramming in the first place.
Strangely, some of Mercedes' own reprogramming documents leave out steps such as normalizing the idle stop sensor, which can lead to "wandering" or "rough" idle.
-s-
Old Oct 19, 2004 | 02:28 AM
mesallem's Avatar
2000 ML430
i think i need to ground the phone kit since there is no ground cable and i put a v60 kit in a car made for a timeport, the v60 kit has a gorunding cable but my car does not have that prewired, what gauge do i need and where can i get the cable, i think this may be causeing my srs and airbag sensors to come on, when i disconnect the phone kit the sensors go off, could this be because of the grounding, also how would i connect the wires together the best way, should i just use electrical tape?
Old Oct 29, 2004 | 01:30 AM
hoyabob2003's Avatar
'02 C230K Coupe
If you're grounding electrical components, make sure you have a good chassis ground and a good electrical connection to it. At the least crimp on either a wire tap or a spade connector to a grounding screw. Better yet would be to solder the connections. A $10 soldering iron from radio shack would work great and it's not all that hard to do on larger wires like the ones you're dealing with. Poor grounds pick up engine noise which can seriously mess with the sound. You don't want or need that. Hope it helps.
Old Oct 29, 2004 | 02:21 AM
miroj's Avatar
Im wondering if the occupancy wires for the seat have been uncoupled, giving an SRS error due to a lost connection. This is entirely consistent with removing or lifting a seat and loosening the connections to do the work and then not fitting one of the plugs properly afterwards.
Old Oct 29, 2004 | 02:22 AM
miroj's Avatar
The phone controller has a ground in it. If it is running then the phone is grounded.
