Voltage Problem with Timeport Phone
I measured the voltage on the external power wire and it was less than 2 volts, certainly not high enough to recharge the battery. Do any of you have an idea what might cause the voltage to be so low. Could it be a relay? If so, which one?
Also, which wire would likely be the one to turn on the phone (external power, battery feedback), and what do each of these functions do?
4 Battery Feedback
5 Manual Test
10 Ground
14 External Power
Thanks alot,
The voltage on the B+ input should be about 4.5V. If its lower, there is either something wrong with the phone, or the PSE. You can test the PSE by not hooking up the phone but instead shorting GND and AGND as well as TXD and RXD. If you do that the PSE thinks that the phone is connected and will put 4.5V on the B+ wire. If it is still 2V, then well... check ebay for a new PSE.
Thanks for the information, e.g.,
"the phone is turned on by shortening the phone's TXA to GND (I am not kidding). The voltage on the B+ input should be about 4.5V. If its lower, there is either something wrong with the phone, or the PSE. You can test the PSE by not hooking up the phone but instead shorting GND and AGND as well as TXD and RXD. If you do that the PSE thinks that the phone is connected and will put 4.5V on the B+ wire. If it is still 2V, then well... check ebay for a new PSE."
I don't have the right tools (or perhaps it is capability) to short GND and AGND as well as TXD and RXD at least at the coil cord "end of things." What I did do, however, was use a multimeter to attempt to measure a voltage at the 15-pin connector that plugs into the phone. I put the positive probe on pin 14 (External Power) and the negative probe on pin 10 (Ground). I get no reading. However, if I disassemble the phone console and put the positive probe on pin 3 (External Power) and the negative probe on pin 2 (Ground) at the 10-pin connector, I get a reading of 4.5.
It seems logical that something is wrong with the coil-cord, doesn't it?
Here's the wiring scheme that shows how the 10-pin connector connects to the 15-pin connector at the phone.
-s-
-s-
