Sponsored by: Innova
Issues with playing iPhone music via Bluetooth
Old May 12, 2023 | 11:57 AM
Jmarr's Avatar
2022 E53
I have a 2022 E53. Having issues with music played through iPhone via Bluetooth. All was well got the first year. Now when it connects it will show the songs as 43 of 11230.
After playing for 30 seconds the display will show -1 of 11230
(That’s minus 1 of 11230) and it will not play. Have to go back to the phone a start with a new song several times before it will play. Went to iTunes forum and it suggested deleting the Music app on phone and reinstalling. I did that however the -1 of 11230 will appear and I need to do steps explained above. Thinking possibly it might be an MB issue I deleted my phone from Bluetooth and reinstalled it. Same issue still.
Any ideas?
Old Sep 2, 2023 | 09:12 AM
antairez's Avatar
2021 E53 Coupe
Hello, since you're on a 2022 e53, maybe just try using CarPlay instead?
Old Sep 2, 2023 | 09:17 AM
wildta's Avatar
GLE 580
Just want to add that Bluetooth is limited in bandwidth so audio quality will be less. Carplay uses wired or WiFi when connected wirelessly and has a much higher bitrate. Apple CarPlay supports lossless audio via W-Fi up to 16 bit / 48 kHz.
If you want wireless carplay, try this device:
Wired CarPlay Convert Cars Wireless CarPlay, Apple CarPlay Wireless Adapter,Wireless Fast and Easy Use Fit for Cars from 2015 & iPhone iOS 10+(Black) https://a.co/d/23du8km
Old Sep 2, 2023 | 09:19 AM
antairez's Avatar
2021 E53 Coupe
Thanks for the input, what bitrate does Bluetooth support?
Old Sep 2, 2023 | 09:34 AM
wildta's Avatar
GLE 580
Sorry I should clarify, BT can handle similar but it depends on other variables, namely codecs, versions, etc. Carplay is going to be better, wired and wireless, both will play up to CD quality without the fuss of BT. BTW most head units don't play higher than CD quality. I'm not sure what burmester can do but I'd guess it's the same 48 MHz 16 bit unless you have the high end one with 25+ speakers, even then I'm not sure if the head unit can process 24bit files, unless it's the very new ones with Dolby Atmos.
