'05 e320 cdi diagnostics menu?
anyway, dad just got a new 05 e320. we got the benz facotry sat radio, but i installed it. screwed it in, hooked it up, and got it all conected. problem is, the command doenst recognize it. i assume that some sort of menu has the option to "activate" it?
ive seen the mute-1-3 thing and the 5-3-7, and tried, but didnt work. is there a new one, or did i do this wrong.
what is the actual, step by step way to get in there?
thanks.
-took out all of the interior of trunk.
-whipped out the module's bracket
-found the one and only place bracket fits and screwed it in.
-mounted sat reicever on brakcet.
-found only 2 free cables near there, both of which fit the only 2 connections the module had. a round, sat antenna-style one, and a rectangular one with six pins. the cars "prewired", so i assume this is it.
i keep hearing of these fiber optic connection, and i havent one yet.
wouldnt make sense, sat radio sound quality isnt NEARLY good enough to warrant fiber.
ive been rooting around the net, and apparently, one of the diagnistics menus has sat as an option, apparently to turn it on. i tried the 5,3-7 code and the mute-1-3. didnt do squat. i may have to look into that starteek deal. i assume if i go for the $18 deal, i will be able to make a mad dash through all of the files pertaining to the w211 and download them all?
