Sponsored by: Innova
No power fuse for cell phone -Help
Old Nov 24, 2004 | 01:16 PM
breastroker's Avatar
2003 C230 K , 2001 ML320
I was installing the equipment for the Mercedes factory cell phone, PSE and compensator in trunk, cradle in center consule etc. Have voice control installed too.
I installed fuses 13 and 16 in the trunk, fuse 44 under the hood and went to install fuse 40 in the dash fuse holder. Either my factory fuse location is incorrect or I do not have a power connection to where fuse 40 should be.
Since all the other wires are in the car, is this power wire to the 40 fuse connector somewhere under the dash?
See photo at https://mbworld.org/forums/showthread.php?t=89387
The yellow 20 A fuse should be fuse 31
The amber 40 A fuse should be fuse 30
The red 7.5 A fuse should be fuse 42
The blue 15 A fuse should be fuse 41
Directly above 41 should be 40, no connector!
