UHI cradle location Q
Another related question. Is there a provision for a privacy handset for the UHI system?
TIA.
greetingz,
BigSis
-s-
And I do have Audio 10.
Randy
Randy
-s-
Thanks,
Randy
1. To wait for the MHI kit from MBUSA to be released (hopefully Jan 2005)
2. Wait for the UHI version of the v600 cradle. Which I have no idea if it will be RE-RELEASED or not. It was pulled because it was too buggy with the v600. Then if it does come out, Totally gut the entire Teleaid system (or atleast disconnect it) and disable your Central Gateway, Instrument Cluster, and Airbag Module so TELEAID = NOT PRESENT. Then install a Euro UHI kit.
3. Swich phones to a different model like Sony Ericsson T637 and use the UHI kit after doing the above. There's not much hope for the v600 at the moment for UHI.
UHI definitely doesn't work with a 2003 model COMAND; it if gets upgraded, I am not sure if it will work.
I suspect MHI doesn't work with 2003-2004 COMANDs either.
The older V60 kit (with the coily cord handset) seems to have some bugs with the newer COMANDs (2005 and Euro). Not just the phonebook issues.
This is yet another thing that is getting extremely complicated extremely quickly with the different versions of COMAND out there.
-s-
Thanks again,
Randy
Thanks again,
Randy
At that point, you may as well add navigation...
-s-
