Sponsored by: Innova
How to wire new OEM LED headlights in an old car
Old Nov 6, 2025 | 08:44 AM
Niek's Avatar
G500 2005
I have got a set of new LED headlights that I eventueally want to install in my 2005 (halogen) W463. (fitment I worry about later) But first I want to test them. Does anyone know how to wire them? The connector on the units are 14-pin but only have 6 pins in use. (1,2, 4, 6, 7 and 8). Can you just put 12v somewhere?
Thanks a lot.
Old Nov 6, 2025 | 11:19 PM
Alexie's Avatar
Do not just apply 12v. You will likely destroy the LED modules. They require a specific CAN bus signal from the car's computer to function. For a test, you need a specialized power supply that can simulate the CAN signal. Your best bet is to consult the wiring diagram for the specific model they were designed for.
Old Nov 10, 2025 | 11:10 AM
Niek's Avatar
G500 2005
Thanks for assisting. I spent last weekend looking for a wiring diagrams of the >2018 model. No luck. If you know where to find one please let me know. On the other hand, If there's a computer in the headlight that needs a signal, I still don't know what the signal looks like and how to simulate it. Is that do-able? My job is in home/professional lighting. I would say; can I disconnect the controle unit and feed the LED's directly with the voltage or current they need to operate?
Old Nov 11, 2025 | 11:13 PM
Alexie's Avatar
Don't try to run the LEDs directly. The car's computer needs to communicate with the headlight control unit. Bypassing it will cause errors. Look for a plug-and-play adapter harness from a specialty lighting company instead.
