MD Docs for dash mount GPS antenna? (att MBenzNL)
'02 C240/6
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hi,
I have an '02 C240 retrofitted with COMAND by MBenzNL. I recently took my car for warranty work behind the console. When the dealer returned the car, the COMAND could no longer see any satellites. I suspect they didnt know how to deal with dash mounted antenna instead of the teleaid antenna that is used in factory installations. I recall Steve mentioning that the use of the dash mounted antenna was even recommended by MB. Is there any technical bulletin or other "official" source that details this? I want to go back to the dealer and with some ammunition to force them to fix the system. Will appreciate any help. Thanks!
'02 C240/6
I am not sure...
I am not sure if they forgot to connect the GPS antenna or not. I suspect that is exactly what happened, or maybe they plugged in something else (the teleaid antenna?). I refused to accept the car that way (it was closing time) and left the car with them. I have yet to hear from them.
I just have a feeling that they will come back with some argument blaming me for use of aftermarket stuff. Since I suspect that the use of the dash mounted antenna is actually supported by MB, I want to have some tech bulleting, part number, or something to rebut.
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
-s-
Its gonna be real hard to go in with "ammunition" as you have essentially voided your warranty on any connected components. It does not matter that they are "original" parts made by mercedes for mercedes. They are grey market parts not supported my MBUSA, and they are the ones who carry the warranty. US cars have a longer warranty covered by MBUSA, which is like a subsidiary of Mercedes. You cannot expect to take a modified car in for service or repairs and have it come back perfect every time, the techs are not familiar with this sort of system, they probably have never seen anything like it.
There is also no bulletin supporting a dash mount GPS, for USA cars. I have never even heard of one before, and cannot see how that could possibly work any better than the factory antenna on the roof.
Former Vendor of MBWorld
some slow@$$diesels
1) a comand is a comand...regardless wether it is for the US or the ROW market - THEY ALL ARE THE SAME AND ALL USE THE SAME CONNECTORS...if a tech is not familair with comand - so be it...but not being familair wit a EUROspec comand where as the tech is very familair with US spec comands is not(!!!) possible.
2) the connectors are all factory connectors...the tech can not see the connectors were not crimped on from factory as there is NO difference with the crimping from factory (using the proper crimping tool)
3) the underdash GPS antenna used by us is a factory MB antenna and is located at the position MERCEDES RECOMMENDS PUTTING IT WHEN RETROFITTING AN APS30 NAVIGATION SYSTEM...and as Scorchie pointed out in which WIS bulletin it can be found - it definitely exists. Nobody said that an underdash antenna works BETTER then a glass mounted antenna (yes glass mounted as the original antenna is NOT mounted on the roof)...what was said is that it doesn't work worse!
The following WIS documents (official MB docs - in this case about retrofitting an MB nav system) show pictures of GPS antennas mounted underdash:
AN82.61-P-0001P
AN82.61-P-0001PA
AN82.61-P-7474-04PB (very extensive bulletin about this particular topic)
greetingz,
You are still adding devices that A) were not originally installed on the vehicle
B) not installed by a dealer and C) not approved for use on U.S. spec cars. There is no warranty on any of it, forget it, end of conversation.
There IS a difference between the comands, otherwise they wouldn't offer different versions for different parts of the world. Legal liability is a big reason why. It is illegal to activate those t.v. screens everyone is so fond of, and I damn sure wouldn't get caught doing it. You can rest assured that if anyone gets hurt or killed as a result of some inattentive driver watching t.v. that its going to get really ugly when the lawyers find out.
If it is truly important to the customer to have a comand retrofitted, then using parts designed for that area of the world would certainly be the best option for all parties involved.
2015 E250D
Steve does install Euro comands and USA COMANDS depending on what the customer wants. If installing things on your car was a problem with warranty, NO ONE WOULD EVER INSTALL ANYTHING ON THEIR CARS! It's a matter of personal preference and also a matter of the dealer caring or not. Most dealers don't care. As for comands, there is NO PHYSICAL DIFFERENCE in comands. Only in the way they operate. There is NO WAY a dealer can complain of a comand installed. I have installed several myself, sold several more, and steve has sold and installed hundreds of them. I HAVE NEVER HEARD OF ANY PROBLEM WITH ANY WARRANTY ISSUE.
Originally Posted by NorCalGregclk55
Does not make any sense. THat would be like saying if you add a Sat. radio...or DVD video or add aftermarket speakers it will void your warrenty.
Basically, if you didn't purchase the part in question from a dealer, don't expect it to be covered. Even if you did, coverage is only limited to defective parts.
Example scenario: Customer takes car to independent shop to try and save a buck. Customer has that shop install a Mercedes remanufactured transmission, purchased from the local dealer. That transmission carries a warranty, regardless of who installed it.
Now things get interesting.... Customer brings car to dealer, because the transmission is not working properly. The independent wipes his hands of the situation, because Mercedes is responsible for the warranty on the unit.
If the transmission is found to be defective, it will be replaced under warranty, and the dealer will do the work.
If the installation was improper, transmission was not correctly adjusted, or some other engine problem is causing the issue, it is NOT covered.
Want to install speakers? Go ahead. Don't expect mercedes to warranty the factory amplifier though, should a problem arise.
Want to install some fancy gizmo on top of your dashboard? Go ahead. Don't expect mercedes to cover removal or reinstallation should the dashboard need to be removed for some unrelated repair. The gizmo was never there from the factory, so why should mercedes be responsible for the extra labor?
Read through the boards, I am sure you are aware of all the people commiting warranty fraud of one sort or another. Lowering cars, wearing out ball joints or what have you, return it to stock to get the parts replaced for free.....
Mercedes will usually do right by the customer, cut the slack, go the extra mile etc... But remember they are doing you a favor by cutting you that slack. Pushing the envelope, when you know you did something you shouldn't have in the first place, is just stupid.
To cast aside any shadow of a doubt, "going in with ammunition" regarding an antenna that shouldn't be there, is futile IMHO. They did him a favor by not charging him for dealing with that system. If they did him a favor, why is he acting like a jerk about it when something went wrong? They probably DIDN'T KNOW anything was wrong, because that system is simply not something they ever have to deal with.
I am not afraid to bring up the other side of the issues, they are often ignored here. Modifying vehicles is a risk a customer takes. More often that not, you will get away with it anyways. Don't make the mistake of thinking you will always get away with it, if you get caught in a situation you know you caused then deal with it. People just need to be more aware of the reality of these situations, instead the the sugar coated world that is gladly passed around on the internet. I am just bringing you the flip side of the coin, if you will. Nobody else seems up to it, and it will give you a better understanding of what to expect when you car goes to the dealer for whatever reason.
My.. my... this is getting interesting!
I know it is early in the morning but I should already get the beer and chips and watch the fireworks!
Hi,
To better understand this situation, what exactly was wrong with the "back of the console" that needed warranty work?
'02 C240/6
My air conditiner was shutting off on its own when in auto. Dealer said it was some air conditioner flap malfunctioning. They needed to remove the console to replace.
It turns out that they simply forgot to connect the antenna. They reconnected and everything is in working order.
'02 C240/6
Steve, thank you for the bulletin references. I ended up not needing them in this situation because the problem was that they forgot to connect the antenna. But they will come in handy if anyone has an issue in the future.
some slow@$$diesels
It won't void the complete vehicle warranty. It does void whatever you decide to connect to or replace with aftermarket.
If you decide to add your own OEM accessories, warranty does not cover improper installation.
greetingz,
I see you take defending your ripoff business very seriously....
I imagine that if I made thousands of dollars doing questionable work and somebody tried to shed a little light on the matter I might attempt to make that person look bad also.
You have just shed a lot of light on how you do business. Making personal attacks on not just myself, but every other mercedes tech in the US will not help you grow your business.
I have refrained from elevating to this level so far... But since you are so desperate to go there, I am certainly willing to follow. You are all too eager to offer complete bull**** solutions to simple problems, just so you can sell more parts and crappy install jobs. If the installation was performed properly as you say, and there truly wasn't anythng different from the factory, there wouldn't have been any problem. Fact is, your service cannot stand up to any real scrutiny. You don't offer anything that cannot be done elsewhere for less money. You are a con artist, and I will point this out in every post you make from now on.
some slow@$$diesels
Originally Posted by MBenzNL
I see that saturnstyle knows the US MB techs better then I do...maybe his story about MB techs looking like complete ignorant fools wasn't so far fetched...eventhough I still think otherwise
greetingz,
'95 S500C, '96 C36, '86 190E, '72 280SEL
Saturnstyl, IMHO, you are way out of line. Although I have never done business with MBenzNL, in every forum I have seen him participate, his actions have been helpful and professional. I have seen no reason. whatsoever, to accuse him of being a ripoff and con-artist.
'02 C240/6
Saturnstyl, are you really an MB Tech? All the ones I have met seem to be very tactfull and respectful individuals... The ones at my dealership know that I installed my COMAND aftermarket and they are very impressed -- had to be told it was so. The manager even updated the systems to show that my vehicle (by VIN) was equiped with a COMAND system (I don't know what that means though)
2015 E250D
I have to agree.
'02 C240/6
Originally Posted by sunman
He updated your vehicle data card. That is something not usually done by dealerships as most don't know how to.
I am so hurt... On your ignore list just like scorchie???? I figured you would have tag teamed me long ago.
I will not be afraid to question the business ethics of someone who travels from another country, to the US and performs questionable modifications. The vast majority of what you do is available locally, but none of us "fools" will perform the illegal modifications you so willingly do. Perhaps coming from another country truly limits your liablility in these legal matters.
I do not follow your crowd, and I am not ashamed of it. I questioned your legitimacy as you have questioned mine. I am sure your followers will disagree with me, but such is life. Your business practices ARE questionable, and there is nothing you can say to repair that. Your responses to my points were nothing like anything a truly successful business person would have responded with.
You provide an overpriced service that is more readily obtainable locally. You surf these forums and prey upon anyone who makes an inquiry about a phone or comand or what have you. Knowing these parts are obtained through channels that are better to service these individuals, you attempt to hawk your wares while providing misleading information. Honestly, why would someone travel to another country to install a radio in someone's car unless they were making a huge profit from it? That couple with the fact that you basically don't have to provide support for any of your products brings me back to what I have thought all along about your MbenzNL enterprise. You are a con artist.
