Fuel Rail Pressure
Fuel Rail Pressure
Greetings
Can anyone tell me where I might locate the Fuel Rail pressure access point on a 2009 B200 Turbo.
It usually looks like a schrader valve on a bicycle tire.
Thank you
Thank you
Hello, not sure on your exact model but i noticed in this diagram that there is a sensor for temp and pressure on the fuel rail.
diagnostic tools can read it
Thank you for the information .. based on the diagram, I am more interested in the fuel distributor fuel pressure sensor located on the fuel rail. Unfortunately I do not possess a diagnostic tool or connector to access this. Seems to be an oversight from MB. Will see what I can dig up in regards to a harness of sorts. Thanks again.
