My driver's door controls are only actuated when I open the door half way
2006 mercedes b200
I was a delivery driver for a while a few months ago and I had the window open and rain had come in onto the window and lock controls on the driver's side.
Shortly after the controls would.only work if my door is halfway open. It seems like either a short or however the door controls are actuated it's almost like it has shifted
Obviously you can understand it's.super inconvenient and a pain to not being able to control windows and locks from driver seat un less the door is half open.
I don't see any hinge pin or actuator on door I am assuming this will be an internal part that is shorting or somehow damaged or shifted, I hope.someone may be able to give me a lead to where I can see the spot I need to focus on for.this problem
Is there a hinge pin actuator?
Door a bit more open , controls become functioning
Door open some yet no control
Thanks for any help given
Well you could buy one, the scanner will save you the time and money you would’ve spent getting a diagnostics report from the shop, there is one called FIXD, less than $100
Sorry can’t help with specifics for your door, good luck
