W246 CNG error
W246 CNG error
Suddenly Car runs only with gasoline. Engine stops when it tries to switch to CNG. A Magnetic valve mulfunction?
Xentry gave this error. But didn't find anything from google.
P141B00 A leak (fine leak) was detected in the natural gas system on the high-pressure side
Any hints?
Any hints?
The Xentry has another error
P01A900 Component 'B18/6 (GAS low-pressure and temperature sensor)' or 'Y107/2b1 (Gas high-pressure sensor) has an electrical fault. The system pressure determined by the control unit is implausible.
The B18/6 is on fuel rail. and Y107/2 is on CNG regulator. I guess either is faulty?
I did check the CNG regulator. The Sensor type is Fuel Pressure Sensor 110R-000123CKV4.2
Is there a way to test it?
It does not seems to be the usual analog resistor type.
![](https://lh3.googleusercontent.com/DNCEdtYh4kzMvL176zI0uNCONJaCsAZVIHUAL2rpVLQ2YsCZT3gSxwtrgJwQIp9k6bnQwq1Zf7xGMbh6yHnddqLP6nF-HdEg-NbkWQErvETfrNIun1-_iq7b5_zEV5RhxRuRyvzoZNx2lThBGrO1IgO49-9iAZ18lC_Qcrf7sOaLJq22eDU4nzifcAUCtnPPfcD2BK7496o7IL0DDkUoS1Ks3lvlAHXZS7n0gmWqDWbrxE9U-neAXNZQJLqtEneKLNx6cIAX02zTjRgLZQXXUSAEb450woohR3IeoJJjdtiJidlMNf_sae-lzPqt920quypXD0PFEQX9K3NbC8ri64oaCcvWyn7TSmOHPtQsDmqOD3Y-tO8ZUtTHL2l6tXSHTmC3hAmSG-dWuc1OWzRFOkfC-ak2Mihtp5NUsPDarK2C5w6X9kLlHBecHBluskHaJp0ZXUy5TnLl5q1NFKCGG9O1DFN67srcAEmo1TcMwaWOXrl1dJOgUR-gicwWyhpu2lVwzhvOnVp745KV4mz9dp2_JErvughYTNItETnB4LjlDLGn-w-5b8SiYQc_75pP6Z-xpjID4n8LIbx151nAn0da7V292QBK-OIUceJqts1PwSJZ6ORSQPHngvqO0WvNdldq42T0x_FHShGJ-boPPY-xREu_SO6IZrAHptzeQMNta7tGN_FXHkXrng5Z0OTMZWkguL83dg50xiAzDypjuW-VqKha8eyX32zRk3-Xj1y4f6Wv9YkElvLgE0Pdewc=w910-h1159-no?authuser=0)
BUT..there is an issue with the sensor. It's STUCK. I guess..over time a steel bolt on alloy body will create some corrosion on thread. The nut is 20mm but the bolt part is very thin. I'm afraid that if I apply enough force, the bolt part will snap leaving the part inside the regulator body.
![](https://i.ebayimg.com/images/g/qVYAAOSwUTJfcCzH/s-l225.jpg)
I'll try to add some heat to it first and add some WD40 maybe?
