Front Speaker Upgrade Complete
probably the cheapest things I've ever seen.
For reference the front speakers (non- HK) are 6.5" and the rears are 5.25", although I understand that 6.5" units might fit in the rear doors as well.
I've installed Kicker 6.5" KCS650 2 way speakers and its truly day and night between these setups. The Kickers came with adapter plates which went straight on (no hardware provided). There is plenty of room to drill extra holes if you want to make sure they'll never come off. These new units can be soldered or crimped straight onto the existing wiring so there is nothing to change except making an extra hole in the adapter to send the wires to the back of the speakers unlike the factory units that connnect at the front. The old speakers came out easily once you've removed the rivets with a 5.5mm drill bit.
The Kickers have a bottom mount depth of 54mm before the adapter of 16mm so they fit easily and leave plenty of clearance for the movement of the window.
You'll need to use that same drill bit to enlarge the holes in the door panel and use 6mm bolts to attach the adpater. The speakers then just bolt to that and you're away. The adapter was 16mm in depth. Plenty of clearance at both the front and back to clear the door card and window at the rear. The only tools you'll need are trim removal tools for the doorcards, torx sockets, screw drivers and some cutters, drill, tape, solder or crimping hardware. Wiring is easy with the MB solid green color wire is positive and the wire either black or with a black line along it, being negative.
Old speakers didn't state wattage but were clearly marked 4 ohms impedance.
Next will be changing out the rear speakers and maybe an amp. Link to those installed. They sound brilliant and have transformed the car's audio although the rears still sound crappy. KICKER | KS Series 6.5" Coax
Kicker on the left next to factory rubbish
Adapter plate that came with speakers
Test fit adapter
Installed
Keeps factory wiring
Rear of new speakers
They're a huge improvement over the stock ones, but if it was my daily driver I'd put in a small amp to get the extra clarity and a sub woofer for more bass. I'm happy with the speakers and its clear that the setup isn't taxing them so an amp would be my next upgrade. My ML has the HK system which I like and the amp really produces on that.
