Battery charging light - problem with auxiliary?
Thanks for any help.
In the meantime, clean the corrision off with a wire brush and see if that makes a difference. Unless your main battery is really flat and or dead, if you can start it, you should be able to drive it to get it tested. If you get warning lights especially the esp system, you know your main battery is cooked as well.
