New type of wipers issue W245 B200 Turbo
Old Jun 1, 2024 | 02:05 AM
rif75017's Avatar
Mercedes w245 B200 turbo
Hi all
I have search for all possible post related to wipers issues on W245 but mine seems a bit different.
Back is working but not front, also the wipers are working perfectly with the spray function or even before that when I press the command for an impulse so I would assume that nothing wrong with the motor.
I was confident that one the the wiper yellow relay was in cause so, PITA job for the access was done and I replaced one of the 2 but still the same, I have put the new one on the second spot but again still the same. I can hear the clicking when I activate the impulse function but not when I put the intermitent or speed 1 and 2 function. Could it be the command module? I have not seen anybody with that issue so I am quite in the dark and that command is not that cheap when new.
Old Jun 9, 2024 | 02:33 PM
rif75017's Avatar
IN my case, FYI, it was the command that was the root cause. All good after replacement.
